Brake cyclinders keep seizing up
Your calipers would likely benefit from a piston cleaning as described on Lyndall's website:
http://www.lyndallracingbrakes.com/service_tech.htm
The pistons have difficulty moving smoothly due to the accumulation of brake dust, etc. over time and with a 2001 bike they're probably overdue for a good cleaning; or, as the previous poster suggested, a caliper rebuild.
HD sells a kit with new seals that is modestly prices.
Carl
Carl
My bet is your problem is internal (inside the caliper behind the dust seal) since it an 2001 . Should have dot 5. Someone may have dumped 3 or 4 into it. Someone also could have dumped some trash in the master cylinder and its hanging it up there. You really need to have someone pull it all down, inspect it, replace the caliper and master with new kits and fluids if it's beyond your expertise.. You do not state miles but if I was doing it I would throw you pads on and take a look at the rotor when you redo it like this. 30K wore my rotors to minimum thickness. I can not think of a more dangerous thing then a messed up front brake.
MEDEVAC247
01-13-2014 07:11 PM
