Bearing burned out.
Hey Dawg beings that you brought up the oil thing. I have moved to AZ where it is getting HOT and have been running syn-3 in all 3 holes of my '09 Ultra and have been worrying about the heat. My question to you is do you think i should change to something else?
Thanks
Jim
Thanks
Jim
Received 75,086 Likes
I was on a road trip through Arizona when a grinding sound started coming from my primary. Took it to a dealer in Flagstaff and after they tore it apart they found the main bearing burnt out and the rotor and cover broken apart. Cost me 500 bucks to fix it but I was able to continue my ride
Big thanks to Flagstaff Harley who was open on Memorial day.
Anyone heard of this problem on a bike with only 23,000 miles on it?
It is true that the SE comp does not appear to like certain oils. Used to be able to run ATF without issues, but with the SE comp that appears to cause issues. Fretting has been wreaking havoc on the SE comps. The jury is still out, but several are running Formula + and having less problems. I run Redline MTL with the SE comp and will be pulling it down at the end of the season to see how it has faired as far as fretting, etc. I have not had any bearing issues on my 08 thus far with 24k on the clock.
It happened twice on my 07 and 2nd time it tore the crap out of transmission bearings too but since then the tech recommend quality gear oil and I'm using Red line no problem since then. Tech said whoever gets hard on their 07s had this issue.But my warranty and ESP took care of it.
BTW, I definitely don't "get hard" on my bike and changed the fluid every 10k or sooner, so I can't use either as an excuse for this failure.
Anyone who has a major repair like this just after the warranty expires should ask about this goodwill warranty coverage.
Has HD ever produced a TT or SB on the early SE comps? Are the dealers seeing it fail with any abnormal regularity?
