Yes, I AM opening this can of worms! (HD Stage 1 Download)
OK, so here's the deal: I love my new Ultra Classic, but the motor wheezes just a bit at mid-rpm's - need a bit more air and fuel.
I'm not thinking about a full aftermarket Stage 1 kit, but I'm looking at the HD Ventilator air intake and the ECM download.
I know, I know.... Fuelmoto, V&H, etc make great Stage 1 options, but I'm not interested in all that. I like the stock pipes just fine, thank you, and the kit I'm thinking about is quite reasonable in cost for what I think would be a measurable performance improvement.
So here's the question: Does HD market the Stage 1 download for the stock ECM anymore? The P&A catalog seems to "hint" that it is available, but I seem to recall someone saying that they stopped marketing it and now only have the more expensive Street Tuner or Super Tuner.
You can still get them from the dealer. Its no longer an add-on module, its an actual software download to the ECM. The dealer will charge you for the software and about an hour labor to reprogram your ECM.
That said, I wouldn't count on it doing much to richen your mixture. Its an HD product and they still have to stay within EPA guidelines, which means you will still be running lean. It does make a few changes and raises the RPM limit to 6200, but nothing with the mixture compared to what a tuner would do.
When I looked at doing it the cost was somewhere around $200 give or take. Decided against it because of the cost vs. what it did. Added another $99 and got a PC-V from Fuelmoto with their map.
The past two years I have been running a hi flow air cleaner and duals on my 08 with just the XIED's. Had a little extra cash this winter so I did the Stage 1 download from the dealer, wished I had done it sooner. Very pleased with the increase in performance...mone well spent.
+1... get the download to raise rev limiter and a better spark table. Then add the download XIEDS to skew the O2 signal and therefore a richer mix... good combo. But make sure this all you want to do though, as the money could be spent toward a SEPST through which you could do both the afr, timing, and a whole lot more now and down the road.
