Weird brake/lights problem I need help with!
2006 Street Glide is the bike in question.
Long story short.... got pulled over last night for no running lights. Turn signals and rear light were off. Brake light worked with both front and rear brake. I got home and replaced the fuse (It was burnt up), and all the lights come on.
With the fuse replaced, the brake light is constantly on. There is no change in brightness when the brake lever is pulled. It's BRIGHT all the time. I replaced the front brake switch in the handle bars but it made no difference. I tried unplugging the rear brake switch but the light stayed on.
I also noticed tonight that if I pull the light fuse, when I pull the lever and the brake light comes on , all the running lights come on too (Turn signals). WTF? I'm stumped here. Could the brake relay in the fuse box be bad?
I also can't get my rear valence light to come on (The one on the bottom of the fender). It's just off. Is that a bulb that can burn out or is it LED?
RoadHog659
11-30-2014 04:35 PM
