Red Hot Rear exhaust? HELP!?!?!
The rear cylinder is behind the front cylinder. It gets less air, and typically runs hotter than the front. Certain Tuners address this to some extent. The fact remains, the rear cylinder even in a well tuned motor runs hotter. It is not at all uncommon to see the later Harley's rear pipe right where it exits the head glowing red at night.
Some progress--no intake leak (WD40).....pulled exhaust and placed TWO SE gaskets in the place of the V&H---thought I felt exhaust and kept refitting and refitting----but no movement of tissue and swirling of CIG smoke when testing for leak (I'm definitely paranoid...lol). Tried to revamp the fuel at throttle settings (1550-6250) on PCV--from 5 all the way to 50. Still got some popping. Night time....both pipes are poppin blue flames at times....when decelerating. So....although my Fuel Moto map is WAYYYYYY better than the PCV website tunes....I guess I'll be calling up Jamie/Keith this Monday. I'm sort of stumped and don't have the experience to really TWEAK the power commander on my own---thanks for all the help.
J-rod
J-rod
Without AFR feedback, any attempts at tweaking would be a shot in the dark. Fuel Moto will get you fixed up. In the interim you could add 5-10% fuel in the idle-3k RPM, 2%-60% TPS cells, no way of knowing exactly what it will achieve, but it should enrich enough to cool you down a little and avoid any damage, until you can get another map.
J-rod
J-rod
Break051
06-18-2019 07:11 PM
