Bad master cylinder?
I have a problem with the front brakes on my RK and I’m not sure if it’s a master cylinder issue. When I squeeze the front brake the bike stops fine but the small piston that pushes the brake lever back to its normal position moves at a snail’s pace. Once I squeeze the lever I have to use my hand to push the lever back and hold it until the piston finally moves out and touches the lever. If I don’t do this my brake light stays on. The brake light switch is fine so that isn’t the problem. I took apart the switch housing and verified that the piston isn’t moving as it should. Is the piston motion controlled by the master cylinder or is there a spring or something else that pushes it out? If the problem is the master cylinder would a rebuild kit fix the issue? Also is the rebuild kit easy to install or it fairly complicated?
Thanks for any advice!
