wire connectors
Old 06-03-2011 | 03:52 PM
ajohnston78's Avatar
ajohnston78
Default wire connectors
when you are installing apes and you have to pull those little pins out of factory connectors what are you using to pull them out? Where do you buy the tool if needed and also are you soldering those extensions or just connecting them and shrunk wrapping thank you
Old 06-03-2011 | 03:57 PM
07RoadHawg's Avatar
07RoadHawg
I soldered and shrink wrapped everything. As for removing the pins... I know it's a PIA, but I cut mine off and redid them with Deutsch connectors. Easier to disassemble next time if I decide to change bars again. Likely scenario since I can't ever quit screwing with stuff.
Old 06-03-2011 | 03:59 PM
usmc3468's Avatar
usmc3468
Use an awl and put it in the female side until you hit the clip and push down and the wire will slide out. Do a search on Youtube I believe there are some videos on this.....I think.
Old 06-03-2011 | 04:01 PM
jjnoble's Avatar
jjnoble
Use any kind of hard wire that will fit into the hole, I used a safety pin from the baby's diaper. I dulled the point a bit and it worked fine. Anything that will fit and won't bend will work.
Old 06-03-2011 | 05:13 PM
BBStacker's Avatar
BBStacker
Paperclip, safety pins, safety wire works good too. Not really that big of a deal. Did my wiring when I went to 575's in about 15 mins.
If you do cut, yes solder the wires. Only major draw back to this is an increase in bulk due to the soldering and shrink tubing. Other than than.....
Take your time.
Old 06-03-2011 | 07:55 PM
07RoadHawg's Avatar
07RoadHawg
That's why you stagger the joints along the length of the wires.
Old 06-03-2011 | 08:05 PM
SE120RG's Avatar
SE120RG
I used a dental pick tool I bought at harbor freight. Makes the job easy. I would guess that any fine point would work like mentioned above. I was concerned about cutting and splicing the wires, read a lot about it changing the ohms of the wire and I didnt want to take any chances, especially with the TBW
DanHappy
03-11-2015 08:41 PM
TylerBoehm
06-11-2014 02:14 AM
1931jamesw
08-21-2011 04:01 PM
boduke883
06-08-2011 01:37 AM
PFIRE
04-23-2011 02:49 PM
Quick Reply: wire connectors
