clicking sound from primary
I'm getting a clicking noise whenever i start to take off in 1st gear, doesn't do it till it's warmed up, sounds like it's coming from the primary can't really tell. anybody else ever heard it?? the bike only has around 1110 miles and it's stock except for the slipons
yes i have, i even told them when i took it in about it, they said they check it out, when i left it didn't do it, but it was cold, but by the time i got it home and pulled it in the garage i could hear it again, i checked the fluids and was OK, whatever it is it has a metallic click to it, so that can't be good. like i mentioned it only does it when warmed up first taking off just a quick click! and whenever i pull in the clutch to go around a corner is when i can hear it.
thanks
+1 on the clank when the clutch is released...notice it more so when travelling at slower speeds/lower revs.
Have changed to the Screaming Eagle compensator and put in the heavier clutch spring.
To me ie sounds like the chain is slapping around inside the primary?...slack adjuster/tensioner maybe?
3,500 miles on bike...been doing this clanking for around the last 1,000 miles.
Mine does it too. I had the Harley dealer at House of Thunder in Morgan hill look at it their service manager said that it was normal and went as far as sitting on my bike while running and in gear pulling and releasing the clutch lever fast making the noise repeat at will. didnt seem right to me but at this point all I can go on is the word of the professionals.
