How much lower is the Road King Custom?
Curious,
I'm going to a Road King. I ride a lot in the mountians, and was researching the Custom, and discovered it was lower than a RKClassic and Standard. How much lower? How much ground clearance do they give up? I despise grinding floor boards on every turn.
Thanks
Thanks
The Road King Custom came with 12" air shocks on the rear. So, 1" lower in the rear over the other two. The fronts are supposed to be the same height giving it a very slight "rake."
As far as scraping, I get into the twisties that we have here in SoCal. I've only hit my board once. Keep in mind that the streamliner boards are narrower than the boards on the other two rks.
Hope that helps!
E
Hope that helps!
E
Had a shock go bad on my 07 RKC. Replaced it with the low profile shocks. A riding bud has an 06 Custom. It appears the bikes are at the same height. I'm not sure that the custom front end isn't lower, but I do like the slight rake on mine.
Anyhow, I live and ride moutain roads. No problem.
the big differences in the custom vs standard road king are cosmetics. different engine treatments, more chrome, hard leather saddlebags, and of course, the windshield. i'd get rid (actually i did) of the chrome windscreen and go with the stock riser cover and a detachable windshield. you also lose the passing lights with the custom, and cruise control is an option, not standard.
they only made the custom from 04 to 07. 07 being the only year available with the 96''/6spd.
ground clearance difference is .400 or about 3/8".
Similar to a Street Glide, of which I scrape my boards all the time. On the model you can raise your floor boards about a 1/2 inch. But sooner or the later the better you get you are back to scraping. Just common sense.
Also incorrect advise leaning your body first, to controll the bike learn counter streering and throttle controll through your turns. (Totally different thread). That is what precludes scrapping and wobble.
