SE211 Cam / 97" S&S Big Bire Kit
Will the two work together?
I ride a 2005 Road King Custom. It currently has the aforementioned cams and Stage 1, with Rinehart S/O's. Fuel is managed by a Power Commander.
I'm happy with my current set up, but the bike has valve-itis (just added the third quart of oil in slightly less than 3K miles), so if I am going to take the time to fix it, I think a big bore is in order while I'm at it. If the SE211 cams will work with this kit, I think I like the S&S for the cost/benefit. I don't want to buy new cams though, so I would take a look at another set up if this is not a marriage.
I'll be doing the work myself. Any input is much appreciated.
As far as the head work goes, what kind of head work are you referring to, Jayson? Is it needed?
If you have a ring problem...now the big bore kit is your cure.
Good luck.
I'm all for big bore kits but if you have valve-itis, a big bore kit doesn't fix that. If you are thinking you're losing oil across the valve seals (valve-itis?) then you should put new valve seals in it...and sprinkle in some port work on your heads as well.
Good luck.
Good luck.
Thought I would put in a big bore while replacing valve seals. Am I on the wrong track? I don't think it's a ring problem as much as I think it's a valve seal problem, which was prevailant in 05's...as I have been told by my local dealership, and have read here numerous times. I figured that the big bore kit would get rid of the need to have work done to the heads and save some time, while ultimately giving me a little more punch out of the motor for maybe $200-$300 more...roughly guessing.
doorsidedown
09-18-2009 08:53 PM
