For those of you using the Power Vision....When bumping up the rev limit with the Power Vision will the tach show/go to the set limit or will it stop at the factory set limit like the PC V does when you use it????
Maybe Im not asking the ??? right. When using a PC V.....even though you have the revextend turned on the tach needle will go to the stock ecm setting and the needle will stop/hang at that spot even though you can go further up to 6200 RPM...the needle on the tach wont show that though..it stops around 5200 and wont go higher. Does the Power Vision have the same problem??
My '07 isn't affected by that PCV limitation, so I can't help. If you'll post this question here you'll likely get an answer.
