weird things - singals flash, guage lights out blowing acc fuse - help
Just changed out my bars...turned key on ...double flash on signal lights on console...then stereo blasted wide open...shut if off, same thing....and on on...also, I could not turn volume up...could turn it down though.
loosened clutch side and wiggled wires, then it works fine for turn on and up volume...odd time signals flash...but now my accessory fuse (15 amp) keeps blowing....
help please!!!
help please!!!
Found it! Went to the source again.....that gave me problem...the volume...could only see a little mark on the sheath...cut it open and there it was...two pinched wires grounding each other out....liquid taped them up, taped sheath and put some liquid tape on the joins, put a 4th fuse in - and....perfect!!!
10Bones
Electrical/Lighting/Alarm
04-10-2018 08:33 AM
scorpion65
08-16-2016 10:16 AM
