Neutral
Old 05-31-2011, 12:25 PM
usmc3468's Avatar
usmc3468
usmc3468 is offline
Same here. Had my 1000 mile service done and it may have helped alittle. It is still hard to find it.
Old 05-31-2011, 12:28 PM
Hamps's Avatar
Hamps
Hamps is offline
Originally Posted by Texas Fat Boy
Me neither garand,
I use the heal shifter 1st (slight tap), finds it right away usually.
Plus 1 on heal shifter. Go to 1st and use heal to tap back and it finds it right away. I also use Amsoil Heavy Shock 75/90.
Old 05-31-2011, 12:44 PM
zfdtruckman's Avatar
zfdtruckman
zfdtruckman is offline
Old 05-31-2011, 12:50 PM
IzZy63's Avatar
IzZy63
IzZy63 is offline
now thats a Curveball in Harley Davidson Talk.
Old 05-31-2011, 12:54 PM
nvsteve's Avatar
nvsteve
nvsteve is online now
Same issue with my 07 when new. Changed to (synthetic gear lube of your choice) and had improvement within 2 blocks.
Old 05-31-2011, 04:24 PM
Keyboard's Avatar
Keyboard
Keyboard is offline
6th Gear
I have the same problem with my 2011 Road King Classic. I submitted a post about it here. It's a PIA to find neutral.
Old 05-31-2011, 05:13 PM
GPHDXLC's Avatar
GPHDXLC
GPHDXLC is offline
My new 11 RK was almost imposable to get in to neutral when new. I just got done with the 1000 mile service with Amsoil in all 3 holes and 300 miles later, it's better, but still harder to find then my other 3 Harley's I had.
Old 05-31-2011, 05:34 PM
kdfcogwheel's Avatar
kdfcogwheel
kdfcogwheel is offline
I had that problem on 2010 Ultra Limited when new. After a change to Redline Shockproof and about a good 10,000 miles, it is easy to find neutral. I now have 11,285 miles and have only adjusted the clutch cable to specs. No other adjustments yet.
Old 05-31-2011, 06:01 PM
stub's Avatar
stub
stub is offline
FWIW: I had same trouble until I greased the shifter at the pivot point.....
-=stub=-
Old 05-31-2011, 06:06 PM
Drat's Avatar
Drat
Drat is offline
I put in Mobil synthetic at 1000 miles and now its easy to find. When it was new I had to roll it about a foot to allow it to move in to neutral. As others have said, change the fluids and adjust the clutch.
Quick Reply: Neutral
