I put slip on mufflers on my 05 and they keep sliding rearward. I reset them and tightened clamp as tight as it will go, but they are moving again. What am I missing?
use new clamp,haley ones ,not the ones that came with aftermarket slipons.u may have overtightened already and put a taper on the headpipe if that is the case u can use an exhaust expander to straighten it out first.
Yup it's your two muffler clamps, but don't use haley clamps, use Harley clamps
when properly tourqed they stretch and should not be reused,many including myself have gotten away with reuse,but it can leed to the problem your having.
May need new clamps but also make sure the clamps aren't pushed to far back on the slip ons. If you get them back from the edge to far they won't stay tight.
