Speedo bouncing, bikes dies, radio quiet
Old 05-30-2011 | 10:55 AM
dkparks's Avatar
dkparks
Unhappy Speedo bouncing, bikes dies, radio quiet
Any help on the following issue would be greatly appreciated:
I was riding my bike up to a friends this morning when my speedo needle caught my eye. It was all the way to zero and then shot up to my correct speed. Did this a couple times. Every time it "died", the volume on my radio went down. As I exited the highway, the bike died. It restarted fine and stayed running as long as I gave it some throttle at stop lights. I checked my fuses, everything is fine. No check engine light on and everything else is working correctly. Any suggestions?
Old 05-30-2011 | 11:07 AM
steelerdude1's Avatar
steelerdude1
What year is you bike? I have been experiencing stalls, and having to rev it to keep it running, (for me it only seems to happen when it's hot outside) but my speedo is not acting like yours. It was suggested to clean the IAC (Idle Air Control). I just cleaned mine with some carb cleaner, will know if it did the trick in a little while (after my ride today)
Take off your air filter, it is at the 12 o'clock position. I sprayed mine and a lot of black gunk came out. I sprayed it until I got a clean and clear flow. worth a try any way.
Old 05-30-2011 | 11:10 AM
steelerdude1
Here is the thread I started that has some other suggestions:
https://www.hdforums.com/forum/touri...ke-stalls.html
Hope this helps.
Old 05-30-2011 | 11:29 AM
dkparks's Avatar
dkparks
Sorry, my bike is a 2003 FLSTCUI. Will give your suggestions a try. Also will check the other forum. Thanks.
Old 05-30-2011 | 01:15 PM
coolerman69's Avatar
coolerman69
dk one of your battery terminals is corroded or loose.
Old 05-30-2011 | 01:18 PM
socalmoe's Avatar
socalmoe
sounds like a battery issue
Old 05-30-2011 | 05:13 PM
powerstroke8oh8's Avatar
powerstroke8oh8
a friend had the same problem and it was a faulty speed sensor
Old 05-30-2011 | 05:17 PM
carpetride's Avatar
carpetride
Did your gremlin bell fall off?
Old 05-30-2011 | 05:43 PM
Papamte's Avatar
Papamte
Speed sensor. You can pull and clean, and it may be fine for a short while. You will wind up replacing it though! Better to do it now at home , than hoping a dealer will have one in stock while on the road.
The sensor controls the speedo, turn signal cancel, radio volume (speed variable), and will tend to cause idle to drop a couple hundred rpm's hence the stalling effect sometimes.
Old 05-30-2011 | 06:12 PM
justanotherjim's Avatar
justanotherjim
From: kingman AZ. We aren't in hell, but you can see it from here!!!
What I found out also was I had some cracked and loose wires in and around my gooseneck area. Bike would die (worst case) or my speedo would die(least case).
Open up your wireing harness cover and check for loose connections, etc. .
Found out later it was a commen occurance for Dressers around those years, 98-2005
Quick Reply: Speedo bouncing, bikes dies, radio quiet
