Speedo bouncing, bikes dies, radio quiet
Old 05-30-2011 | 07:08 PM
DTTJGlide's Avatar
DTTJGlide
Ditto on the speed sensor.
Old 05-30-2011 | 08:16 PM
09BlueRoadKing's Avatar
09BlueRoadKing
Check the battery cables.
Old 05-30-2011 | 08:41 PM
Bill03E's Avatar
Bill03E
Did you loose all power?
If so , replace the ring terminals on the main circuit breaker, get big fat ones, they over heat with the heat from the engine.
Old 05-30-2011 | 08:44 PM
dkparks's Avatar
dkparks
So where is the speed sensor located anyone?
Old 05-30-2011 | 08:50 PM
dkparks's Avatar
dkparks
No I didn't lose all power. Only speedo, quiet radio. Everything else worked.
Old 05-30-2011 | 08:58 PM
DTTJGlide's Avatar
DTTJGlide
It's on the right side of the bike on top of the trans, has a small allen bolt holding it in. Remove the bolt & rotate it back & forth slightly as you're pulling up on it to remove it, it's a magnetic sensor that's triggered by the teeth in the trans. Being magnetic it picks up steel particles from the trans, as said earlier you can usually clean it off & get it to work again for a little while, but I'd get one on order if that fixes the problem, they usually don't last for long after you clean them, I know.
Old 05-30-2011 | 09:17 PM
03dragonRK's Avatar
03dragonRK
Thumbs up
It's located in the transmission. Look on the right side for a black oblong plastic held down with one Allen bolt. Remove bolt and twist as you pull up. There is an o-ring on the sensor that tends to stick so the twist can break that free. Check the bottom of thei sensor and if it has metal fillings on it you maybe able to clean the sensor and get it to work.
I would first check the battery connections as I had this happen to my 03 RK. Turned out to be a louse negative connection. Tightened the 10mm screw down and fixed the issue.
If you do end up replacing the speed sensor you will need to pull the battery to get at the connector for the sensor so checking the + and - connections is the easy first step.
Old 05-31-2011 | 06:56 PM
dkparks's Avatar
dkparks
Put in new speed sensor today, no luck, same issues. Going to double check wiring harness, didn't need to pull battery so will do that and clean, check connections. Notice the speedo has condensation in it. Anyone think that could be causing the problem?
Old 05-31-2011 | 07:58 PM
Bill03E's Avatar
Bill03E
I don't know of any older harley that doesn't have some moisture in the gauges,that is if they ride it, that doesn't hurt a thing.
Old 05-31-2011 | 09:14 PM
coolerman69's Avatar
coolerman69
Always check the simple things first. I've seen the exact thing happen more than once. Once on my bike 3 or 4 times on others. Its always been the battery cable connection. Even if the cables seem tight on the battery, remove them, clean and re install. Add some dielectric grease to prevent this from happening again.
Quick Reply: Speedo bouncing, bikes dies, radio quiet
