best way to lower
Old 05-29-2011 | 07:13 PM
jgann's Avatar
jgann
Default best way to lower
I have an 2002 Ultra. Want to lower the front and rear more than 1 inch. Any ideas and what would be the safest?
Thanks
Old 05-29-2011 | 10:18 PM
trozenhorse's Avatar
trozenhorse
progressive rear shocks and front springs, have them on all my bikes, bike handles much much better.
Old 05-29-2011 | 11:29 PM
K Melancon's Avatar
K Melancon
Let air out your shocks. Tomorrow when you want to raise it back up. Put air back in.
Old 05-30-2011 | 08:02 AM
VETERAN75's Avatar
VETERAN75
Only go 1 inch on the front because most likely it will bottom at 2.
On the rear the best way is shocks, either air for adjustability or just get shorter shocks. I am running progressive dropped 1 in the front and 11.5 inch shocks on rear.
Old 05-30-2011 | 11:40 AM
Brettcr's Avatar
Brettcr
Progressive drop in kit works the best for the money for the front in my opinion. Not a difficult process just kinda dirty . Run with a heavy fork oil. Just as a note... i dropped mine over 2 inches and i don't come close to bottoming out. The hole i would have to hit would probably throw me before it bottomed out.
Old 05-30-2011 | 11:53 AM
mabitola's Avatar
mabitola
Default 2008 RoadKing
Front Lowered 2 inches w/ progressive springs
Rear shocks were sent out to
http://bitchinbaggers.com/products/drop-shocks/
and lowered 2 inches.
I never bottom out and I ride with my wife from time to time.
Old 05-30-2011 | 11:54 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I put lowering shocks on mine on the rear and that has helped a lot. Was going to lower the front too, but now I do not have to. The rear was enough. I would reccomend the rear, try it and see if it is enough, if not then the front. Also you could look into a shorter seat and skip loweing the thing at all.
Old 05-30-2011 | 12:45 PM
jgann's Avatar
jgann
Thanks for the info
lhgdale
07-19-2013 04:37 PM
08ultragzrglide
08-26-2008 11:08 AM
MNrider
08-07-2008 12:20 PM
keltics mc
07-09-2007 09:01 PM
StreetGlider56
04-07-2007 03:34 PM
Quick Reply: best way to lower
