big sky fan cooling numbers & satisfaction
Morning
I am thinking of purchasing a fan for the oil cooler
1. I was inquiring if anyone on the forum had documented drop in temps with or without it?
2. Were you satisfied with it? There is some hesitation that they might not be able to handle all the water and grime from the road
Thanks
Thanks
My experience with cooler fans is that they do help when stationary and you need some airflow over the cooler, but although they don't stop the ascent of oil temperatures they will slow it down somewhat. The problem with fans in that environment is that it is hot and potentially dusty and wet, and if you install these I would check them periodically for proper operation, as when the bike is running I never could hear them.
Big Sky uses IP54 fans, which have some water- and dust-resistant properties, but I think it'll take time before the jury comes back with a verdict on the long-term durability of these. I also don't know who makes them, the temperature range they're designed to work within, or anything about the thermostat arrangement that he uses. If I was buying one of those kits I would get the fans and use the manual ACC switch on the dash (EG) or nacelle (RK), or add a second.
Over time I'm leaning toward favoring an engine fan as the best solution to cooling when in gridlock traffic, like the HD or Lenale fans. The HD is expensive, and in my case I have no place to put my air horns if I installed one, as the horns are too important to abandon. Even worse than cooler fans an engine fan will be constantly baked by engine heat, and I would want to make sure replacement fans were available at a reasonable price. The HD fan motor alone is $185 MSRP ($132 at Zanotti's), which is very pricey, but I don't know about the price of a LaNale replacement fan. I also don't have any info on how long either fan will last in that environment.
I also thought about rigging a small motorcycle radiator fan that will fit somewhere behind the air horns on the left side of the motor, but I have yet to find one small enough. I suspect (without evidence) that one or both of these engine fans is a radiator fan adapted for that use.
