Starter Kick Back
Starter Kick Back
Hi,
Recently my 05 EG started to have starter kick backs, one so bad that it broke the front shifter linkage out of the socket. So I've read up in the forums and I keep hearing a lot about the Power Commander, as well as the SE compensator. At this point I have done nothing since I've never had a problem like this and like to get some advise on where to start.
I tried the method of starting the engine right away while the fuel pump cycles but I still had kick back, just not as bad as before.
My setup is as follows:
PC III USB (2 years old)
Arlen Ness Big Sucker
V&H Long Shots
Rest is stock
I checked out the SE Comp, but couldn't find one for my 05. Besides, before I spend 200 bucks I'd like to make sure that's the solution. Any help and advice is greatly appreciated.
Thanks a bunch
V&H Long Shots
Rest is stock
Thanks a bunch
I took the bike out yesterday and found that when I press the start button for a spit second and let go and then press and hold to start it works most of the time without kick back. However, during my trials I also noticed that at times when it does kick back there's a kind of singing noise afterwards, kind of like something's still turning somewhere which I would attribute to the starter still turning perhaps??? Another thing that's weird is that while driving I had the bike momentarily stall on me twice. All instruments went dead for a second and then the engine came back. I am now wondering if this is related to the PC III USB? If the kick back is due to bad timing from the PC and also results in the stalling out then the problem might be a faulty PC altogether, or of course a wiring problem somewhere. I guess I will start with the battery and then go on to taking the PC out of the loop. If it still does it then I guess I don't have a choice but to check out the starter clutch. What do you guys think?
Thank you both for the help thus far.
Losing power altogether REALLY makes me think battery and battery cables. But don't automatically assume that the 2 issues are directly related. You COULD have a weak battery and/or loose cables, the starter clutch could be bad, all at the same time that your ignition switch is going south.
Thanks guys. This is getting better by the minute.
I don't have the time today, so I guess next weekend I will start with the battery and work my way through. Please stay posted as I may have more questions as I go along. It seems things got a lot easier with the 06 or 07 models regarding pulling shi. off the engine ... go figure.
So ... I pulled the PC and since I did the bike did not stall on me, go figure. That surely does not make any sense to me.
Anyhow, I went to Iron Horse and the mechanic told me to pull off the starter cap and check the solenoids. I did, but I cannot find anything out of the ordinary. I also have no idea what to look for really.
I attached a few pictures for those who know what they're looking at.
Thanks
Thanks
