Can anyone tell me where I can find...?
I had to take the outer shifter lever off my bike (rear kick?)
Here is what I need to do, I would like to move the front shifter lever to the outside... But then there is slack in my shifter assembly.. Is there someplace I can find a spacer for the spot where my shifter used to be to keep everything tight.
My only other solution is to take a hack saw to the old shifter and put it in the back so it fits?
https://www.hdforums.com/forum/touri...e-shifter.html
I pulled my heel shifter off and then slid the toe shifter out to the end. I took the rubber grommet on the heel shifter off and trimmed it down to the proper size for a spacer to cover the exposed area between the toe shifter and the primary cover. Works good and matches the toe shifter grommet.
