Volt Meter
Old 05-25-2011 | 01:37 PM
old_mikee's Avatar
old_mikee
Default Volt Meter
My volt meter on my 2004 Ultra reads a little over 15 volts whenever it is running. No starting or running issues, but normal is 13 to 14 volts on most 12 volt systems when the battery is charging. This battery is about two months old now.
Is this normal for a Harley?
mike
Old 05-25-2011 | 01:40 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
That's about where my 2011 RGC runs.....not exactly precision quality instrumentation on the dash
On the other hand..... my air temp gauge is right on the money
Old 05-25-2011 | 01:46 PM
slothy's Avatar
slothy
weird you asked this, i noticed this last night.
Old 05-25-2011 | 01:47 PM
vet767's Avatar
vet767
Don't have a gauage on my RK but had some charging issues last year and when I checked it with my digital multimeter it read right at 15 and that meter reads +/- .00001% or something like that. wouldn't worry
Old 05-25-2011 | 01:59 PM
rh8234's Avatar
rh8234
Don't know why, but this cracked me up. The air temp gauge is a total waste of space. I know when it is cold. (My ***** shrink up.) I know when it is hot. (I have sweat dripping off my glasses). Don't need no stinking gauge to tell me if it's hot or cold.
Now with the volt meter - I haven't got much use for that either. What ever happened to the amp meter? All the cars I had in the 60's had amp meters. They were more useful because they told you something about the charging system. All a volt meter does is tell you if the battery is dead. I know when the battery is dead. Bike won't start and I got no lights.
Old 05-25-2011 | 02:08 PM
old_mikee's Avatar
old_mikee
ok, no worries then...First time i paid any attention to it, so I guess as long as it is above 12 volts, I can go back to ignoring it.
thanks for the replies
mike
Old 05-25-2011 | 02:09 PM
shooter5074
Ta Da
Old 05-25-2011 | 02:13 PM
old_mikee's Avatar
old_mikee
I know why they don't use an amp gauge..... Its cause they would have to run a heavy gauge wire to it, and then back from it.
Volt meters do not carry hardly any current...... a little wire is all thats needed for a volt meter..
Old 05-25-2011 | 02:25 PM
wolfman 66's Avatar
wolfman 66
Amp gauges carry very little current. they use a shunt .
greggreen
Electrical/Lighting/Alarm
06-10-2018 07:03 PM
jwaldo
04-10-2014 06:17 PM
vickers1
08-01-2013 10:48 AM
rlj50
04-13-2013 12:08 PM
shagnasty
03-18-2011 03:19 PM
