WO575s on a 2011 Street Glide, what do I need?
Old 05-24-2011 | 03:16 PM
whodares's Avatar
whodares
Default WO575s on a 2011 Street Glide, what do I need?
Hey guys,
I just ordered a set of WO575Bs for my Street Glide. What cables do I need to extend? I've done a search and see mixed results.
I want the least amount of trouble and clean cable runs, so I don't mind spending a little extra for an easier job. So brake and clutch?
And how much longer?
Old 05-24-2011 | 03:52 PM
JRBass's Avatar
JRBass
Been researching this also.. From what I get is Nothing if you want to route the clutch cable under the fairing and not through the hole. Otherwise I think I read a +4 clutch cable is needed.
Old 05-24-2011 | 04:01 PM
Northbound Southerner's Avatar
Should be a +4 clutch cable and that's it. I will be putting mine on tomorrow. I'll put up pics and a review after...
Old 05-24-2011 | 08:28 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
just did mine +4 clitch cable,slightly straightin out the bends in the brake line(by hand).throttle cables were a little snug but with alot of adjusting they are fine.
Old 05-24-2011 | 09:30 PM
mjb765's Avatar
mjb765
Did the same bars on a CVO SG..+3" clutch line and that was it.
Old 05-24-2011 | 09:40 PM
whodares's Avatar
whodares
Thanks guys!
Old 05-24-2011 | 10:28 PM
lifecast's Avatar
lifecast
I thought I heard someone say they dont have dimples so they the wires need to be ran in the bars? Just asking so I will know since this is a mod I plan to do also.
Old 05-24-2011 | 10:36 PM
tat2fatboy's Avatar
tat2fatboy
also should you change out the bushings? or are the factory ones good enough for the 575.
Old 05-24-2011 | 10:39 PM
bmaier's Avatar
bmaier
What he said
Old 05-24-2011 | 10:45 PM
iwillfixthem4u's Avatar
iwillfixthem4u
factory bushings are fine, +4 inch on clutch cable and go with the CVO throttle by wire without the green connector...oh and PM grips....you will love the bars!!
