Any FLHTC owners move the license plate mounting to the Street Glide location if you did how did you do it i have a solo seat on my classic and i don't like it on the loop.(i bought a SG plate mount but it just doesn't bolt up)
Thanks in Advance
Softbrake.com sells a mounting bracket for under the light but does not light the plate. For me I don't care about the light. If anyone gives me Sh@& I can always put the TP on to pass inspection
You might want to check out the Hotop license plate mount I have listed for sale in the classified. It comes with brackets that allow you to remove the stock license plate bar and utilizes the mounting holes of the stock turn signal bar for the mounting points. It also opens up a lot of options to run aftermarket turn signals for a more cleaner and custom look.
just did the softbrake mount. It is a perfect fit and the only complaint I have is I wish it was moon shaped to hug the fender more. Other than that perfect piece of metal and thick enough not to vibrate too much.
