Synthetic or oil
Old 05-24-2011, 06:13 AM
shortride's Avatar
shortride
shortride is offline
Welcome, Skeeter!
Don't be discouraged by some of the replies you will get here. There never has been a dumb question. Only dumb replies.
The HD Forums is the best on the internet. There are so many willing to help new members.
I use Amsoil synthetic oil in all 3 holes. Amsoil Severe Gear 75W-90 in the transmission.
Old 05-24-2011, 06:50 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,148 Likes on 3,669 Posts
Lot's of opinions but you will have to make this decision....If you change your oil at 2500 -3000 miles and don't do 2000-3000 miles trips then with the area of the country you are in regular oil would be fine then again Syn will be fine also...I say it depends on what you feel comfortable with...I personally use Automotive 15w50 or 20w50 full syn that i get on sale at auto parts stores because using motor oil is ok if you don't share the crank with hte clutch....I use formula + in the primary and syn 85w140 in the tranny...Opinions will be in the 1000's....Hey the most important part is to actually change the fluids and not go over the manufacturer recommended intervals.
Have fun....
Old 05-24-2011, 07:16 AM
cromagnon's Avatar
cromagnon
cromagnon is offline
Mobil 1 in engine and Redline in other holes
Old 05-24-2011, 07:54 AM
ocezam's Avatar
ocezam
ocezam is offline
I use synthetic - Mobile 1 v-twin.
My only advice would be to use a true gear oil in the transmission - 75/90 or better. Syn 3 or any other 20/50 motor oil is way too thin for a gearbox IMHO. Yeah I know the Motor Company says it's OK, but it isn't in my bike. When I switched to 75/90 from syn 3 in my bike my shifts became significantly quieter.
Old 05-24-2011, 07:58 AM
riff1006's Avatar
riff1006
riff1006 is offline
Amsoil in the crank, Redline in the tranny and primary. I agree about the tranny. I prefer the gear lube.
Old 05-24-2011, 08:00 AM
santajim's Avatar
santajim
santajim is offline
Syn3 in all 3 holes fore me.
Old 05-24-2011, 08:13 AM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
IMO,SYN runs cooler & gives better protection, Do a "SEARCH" on this site for info. Don't let it confuse you. I run Redline Shock Proof in tranny & will go with Redline Syn Engine & Redline Primary oil at my 5,000 mile service. There are "MANY other Syn to pick from. Make sure you use a Tranny Oil & not engine oil in tranny.
Old 05-24-2011, 09:17 AM
Ronp42's Avatar
Ronp42
Ronp42 is offline
Account Retired
Welcome to the forum Skeeter.
As said before, there are no dumb question's, just dumb answer's. I don't care if you ride a million miles or just start the engine in your garage, Synthetic oil is better!!! As to the brand you use, that's up to you. I would not recommend using a motor oil in the Tranny. A gear oil is better there. I use Redline with shockproof in my transmission. Mobil 1 15/50 in the Engine and Rotella-T 15/40 in my primary.
Old 05-24-2011, 09:27 AM
beary's Avatar
beary
beary is offline
You are still breaking in your motor at 3000 miles, some say even 5000 and regular oil still helps that process even if it is only so slightly. If you decide to switch to synthetic, you will likely stop the rest of the break in, but its also likely you can't notice the difference. So it comes down to a peace of mind. Regular oil causes no harm to the engine what so ever. Synthetic is just a little easier on the engine, expecially with the heat of the summer.
Beary
Biker Bandit (05-14-2020)
Old 05-24-2011, 09:33 AM
Expat1's Avatar
Expat1
Expat1 is offline
Location: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Hi Skeeter,
I wanted to run synthetic oil in my bike but...
I had a chat with an 'old fashion' mechanics who works for our local HD dealership. This person rebuilds HD engines for friends and for his own collection of motorcycles. He told me that all engines including the 96ci better run with mineral oil because we don't have needle bearings on our camshafts (yet). According to him, we wear out our bronze bushings faster with synthetic oil, which isn't the case with SE engines or 103ci and higher.
So I use HD 20W50 mineral in the engine during the time of the warranty, then MOTUL 3000 20W50 (approved by HD) because it has the "JASO_MA" specification for the wet clutch and primary chain. For the transmission I'm trying MOTUL 75W80 because it was blended for hard/stiff shifting gearboxes.
The engine oil must resist to heat+pressure to avoid rupture of the oil film along the cylinders and over the cams, the oil film between the wet clutch plates must not resist to pressure otherwise it slips, and the gearbox needs a higher pressure resistance for gear teeth and shifting mechanism.
The primary chain is the less demanding element of the transmission as long as the compensator doesn't fall apart!
Can one oil do everything or is it simply like the saying:
'jack of all trades master of none' ?
All depends how and where you ride.
Quick Reply: Synthetic or oil
