saddlebag lock question????
Over the winter I had the scoot painted. I took the saddlebags apart but I didn't take apart the entire latch I just removed it from the bag. The other day I was out and about and went to lock the bags and they do not lock. Wtf? I looked through the service manual and it was no help for this. Anyone know if I can adjust this fairly easily? Thanks
I am having a different problem but similar. On one of my bags the lock will turn farther than it should. When I check the nut on the inside of the latch it is loose. When I tighten the nut up snug then the lock will not work! I have to back the nut off again to where its "loose" and then the lock will work. Dont like this as I am afraid the nut is going to finally back off entirely and be lost.......how in the hell do you adjust these locking mechanisms? This is a bag on a 2010 StreetGlide.
I had the same problem. The dealer replaced it. Buy a new one.
adjustment, bag, davidson, disassemble, electra, glide, harley, harleydavidson, lock, locks, loose, saddle, saddlebag, them, tighten
