2009 Fuel Filter change
Old 05-23-2011 | 11:53 AM
Gordon65's Avatar
Gordon65
Default 2009 Fuel Filter change
It's time to change my fuel filter (2009 ultra), I've not been able to locate any info here on the 09's. I've watched the video that is floating around - he did that one on an 04? - I've read all the threads here that I could find.
In the threads that I've read here, I've seen a couple references on the 09's and up being easier - but no details on how. Also, I've seen reference to the 10 screws that should not be used - my manual says nothing about any screws.
Anyone done an 09 or later yet?
Old 05-23-2011 | 11:59 AM
The Q's Avatar
The Q
I swapped out tanks on my '08 Glide and can tell you if you are comfortable wrenching on your bike, changing the fuel filter isn't that hard. There is a thread on here about using a piece of PVC to knock the retaining ring loose. Once the retaining ring is off the top plate is gently manipulated out and the filter housing is right there. The service manual is of some help too.
Old 05-23-2011 | 12:22 PM
Gordon65's Avatar
Gordon65
thanks. what i am also wondering is do the 09's have these ten screws that I've read about on the older ones-and to not re-use them. I do have the service manual, and see nothing about it. I just want to make sure I have all the parts i need before starting. I've read where others have purchased a fuel filter change kit, for $50 or more, all I got so far was a filter and O-ring.
Old 05-23-2011 | 12:50 PM
rg_dave's Avatar
rg_dave
No screws, retaining ring. It shows you how in the service manual. Its pretty straight forwards.
Old 05-23-2011 | 01:02 PM
Gordon65's Avatar
Gordon65
sounds good. thanks!
Old 05-23-2011 | 01:30 PM
RK14SGS's Avatar
RK14SGS
Is there a tool to use? To prevent boogering the ring?
Old 05-23-2011 | 01:44 PM
karbar99's Avatar
karbar99
Yes there is a tool...look for the FUEL PUMP RETAINER RING TOOL here to see what it looks like.
http://georges-garage.com/chassis_tools.htm
To the OP also, here is a thread that may help as well.
https://www.hdforums.com/forum/touri...9-touring.html
Old 05-24-2011 | 07:07 AM
Gordon65's Avatar
Gordon65
thanks! i missed that thread...
Old 05-24-2011 | 08:47 AM
atrain68's Avatar
atrain68
I like Georges Garage tools but that retaining ring tool is way too expensive unless you intend to use it for a living.
Old 05-24-2011 | 10:21 AM
iclick's Avatar
iclick
It only works on '08 and newer anyway, so we with older bikes must look elsewhere. A friend with an '09 knocked it out as mentioned by someone earlier and said it was an easy job. Those with newer bikes might get a group together for a communal purchase from George's Garage. Three friends and I worked-out such an arrangement for tire-changing paraphernalia and it has saved us a ton of money over the years. The communal filter-tool idea won't save as much, I wouldn't think, as you change tires much more often and the cost savings are higher.
Skidbiker
09-30-2015 08:09 AM
doug62
08-30-2015 09:55 AM
robbie52
07-05-2012 10:15 AM
pip369
Carburetor Related
04-13-2009 12:02 PM
dawg
08-20-2006 03:17 PM
Quick Reply: 2009 Fuel Filter change
