Fairings Gasket Adjustment?
I had the Harley Boom Speakers installed on my new StreetGlide and noticed when I got home the fairing gasket wasn't tucked into the fairing on the left hand side about 2 1/2". Not a big deal and I'm sure it would not cause issues of any sort but I notice it and it kinda well, drives me nuts. Maybe I should just try to deal with it?. My question is, is this a simple thing that I can fix or should I make the trip back to the dealer to have them tuck it back in. Not sure if you could loosen just one side or do I need to pull the entire front fairing off?
Thanks for any feedback you may have.
Thanks,
T
Thanks,
T
If it is the gasket around the lower front at the headlight area you will have to use an auto weatherstrip adhesive to properly install it and get to stay put. You will need to remove the fairing and repair, don't forget the masking tape to hold it into place until the adhesive sets, then reinstall the fairing.
If it is the small gasket around the upper left and right , just loosen the 4 fairing screws abd massage into place and tighten up.
