question for - 103 and oil cooler owners
Old 05-28-2011 | 10:38 PM
Egras2k's Avatar
Egras2k
Have not had any problems starting.
Old 05-28-2011 | 10:57 PM
Mathews2's Avatar
Mathews2
I have noticed harder starting when Hot.
Old 05-29-2011 | 05:44 AM
mikebaby's Avatar
mikebaby
Originally Posted by speakerfritz
Just want to know if any of the 103 owners that have oil coolers installed are having the starting problems when their bikes are hot. Seems that some 103 owners have problems starting their bikes when hot, and current attention is either higher torque starters or compression release. So to better understand what is happening....it would be helpful to measure if this is a problem with 103 owners that have oil coolers installed. a bike with an oil cooler does not get as hot as a non oil cooler bike. I noticed easier starts when hot on my bike. Thanks for your comments.
I have the same problem with my '96 with no oil cooler. It's almost as if the starter motor needs more torque.
mikebaby
Old 05-29-2011 | 08:33 AM
bigray's Avatar
bigray
This may also have something to do with the color of the bike.....gray bikes run cooler and ARE cooler, with no issues! SO FAR!
Old 05-29-2011 | 10:46 AM
Punjabi Rider's Avatar
Punjabi Rider
Only starting problems with my 103" was due to week starter and SE compensator if you have new Power pack 103" stock on your bike it already should have SE comensator on it.Lots of bikes have this problem since 07 and gets worse when you start modifying and beefing up the motor.
Old 05-29-2011 | 10:56 AM
Retrop's Avatar
Retrop
Originally Posted by Twinrider
Some forum horror stories and the fact that the moco uses them on its 103 convinced me to add compression releases when I installed the SE103 kit with 255s. If the cams aren't 255s the CRs might not be necessary.
You are going to have to help me on this one. Are you suggesting that the 255 cams raise the compression ratio above what the stock engine would have? Or are you suggesting that an engine that comes from the factory with 255 cams has a higher compression ration than a stock 96" engine has?
Old 05-29-2011 | 11:50 AM
$tonecold's Avatar
$tonecold
Well it appears that the '10 103's have 9.7:1 cpr & '11 103's have 9.6:1 cpr compared to the 96ci's 9.2:1 cpr. This computes to about a 193 psi in cold cranking compression with stock cams. If you install 255's your ccc will rise to 197 psi. These figures are at sea level. As your altitude increases your ccc will decrease. That being said there are other things that can cause hard starts. Does your ignition fire on the first compressing stroke or does it allow your engine to cycle once? Are you at sea level or higher elevation? Is your cpu putting too much fuel in for hot starts? This is something the PC III guys are avoiding by not waiting for the fuel pump to cycle. Some controllers like the T-Max allow you to adjust this. What I can tell you is I have a 107ci with 195psi CCC and an oil cooler and I don't have hard starts when hot w/o the compression releases. I am at 1240 feet above sea level. If I go to San Diego my CCC will rise to 202 psi. At that point I may be glad that I had the compression releases installed.
Old 05-29-2011 | 06:36 PM
Retrop's Avatar
Retrop
Originally Posted by $tonecold
Well it appears that the '10 103's have 9.7:1 cpr & '11 103's have 9.6:1 cpr compared to the 96ci's 9.2:1 cpr. This computes to about a 193 psi in cold cranking compression with stock cams. These figures are at sea level. As your altitude increases your ccc will decrease. That being said there are other things that can cause hard starts. Does your ignition fire on the first compressing stroke or does it allow your engine to cycle once? Are you at sea level or higher elevation? Is your cpu putting too much fuel in for hot starts? This is something the PC III guys are avoiding by not waiting for the fuel pump to cycle. Some controllers like the T-Max allow you to adjust this. What I can tell you is I have a 107ci with 195psi CCC and an oil cooler and I don't have hard starts when hot w/o the compression releases. I am at 1240 feet above sea level. If I go to San Diego my CCC will rise to 202 psi. At that point I may be glad that I had the compression releases installed.
Re: If you inst255's your ccc will rise to 197 psi.all How does a higher lift or longer duration cam (255's) raise the compression ratio?
Old 05-29-2011 | 07:43 PM
103 sedona orange's Avatar
103 sedona orange
IMO, with 103 you should have a compression release. The oil cooler has nothing to do with your bike starting hard. My 103 came stock with both.
Old 05-29-2011 | 10:44 PM
blusmbl's Avatar
blusmbl
It's determined by the intake valve closing point, primarily. Advancing or retarding any cam, including the stock cam, will also move ccp around.
Quick Reply: question for - 103 and oil cooler owners
