anybody have this problem
i just installed se 204 cams.Rode it home from dealer had a very bad lean spot under 2k rpms. I was only still running stage 1 download jackpot mufflers se ac. I called fuelmoto and got a pcv. Just installed fri night much better.If i go to take off on ahill the bike still stumbles will call fuelmoto tomorrow not sure if i need to tweak the map or i have a problem with the bike since it seems to only do it on ahill otherwise i can roll the throttle rite on which i could not do at all before pcv without having a real bad lean stumble. Any suggestions would be helpful
The most accurate method would be a good dyno tune. But, if you're mostly happy with Fuel Moto's canned map simply save a copy of it on your computer & start tweakin' at the locations you think need adjustment. One of the great things about the Power Commander is the ability to make your own adjustments. Go up or down in small increments & make short runs to try the new map out before you start takin' trips on it.
