Those d@#% fairing brackets
Old 05-22-2011 | 08:32 AM
ironhead3fan's Avatar
ironhead3fan
Default Those d@#% fairing brackets
Anyone have as much trouble with these things as I have? I have replaced all 4 brackets at one time or another. This time, I had the right side fairing bracket break at the 90 degree elbow at the top. Didn't replace the bracket this time (which is a real pain BTW), I used L brackets from Lowes, 2 1/4 inch bolts and washers with locking nuts, and a drill. Never coming apart now. Anyone else here have problems with them? (No, I didn't get pics of my fix)
Old 05-22-2011 | 08:37 AM
soos's Avatar
soos
My bud just bought all 4 brackets and the 2 main vertical brackets have been redesigned and reinforced. The 2 horizontal brackets have been redesigned too.
Old 05-22-2011 | 08:40 AM
ironhead3fan
I do have one of the redesigned horizontal fairing brackets. Didn't feel like dropping another $150 again to get all four. Total cost at Lowes was 12 bucks, problem solved.
Old 05-22-2011 | 08:52 AM
dawg's Avatar
dawg
Originally Posted by soos
My bud.........
Miracles never cease..........you actually have a friend?
Old 05-22-2011 | 09:01 AM
HDV-GLIDE's Avatar
HDV-GLIDE
I tried a little preventive maintenance last year while I had my fairing off to replace the two still good horizontal brackets with the newly designed ones.
I used rubber isolator washers between all four brackets mounting points and the fairing. Figured the washers would flex and absorb some of the stress on the brackets and maybe give them a longer life span.
Only time will tell...............
Old 05-22-2011 | 09:16 AM
leadman's Avatar
leadman
Repaired the left horizontal bracket a couple a couple of years
ago by welding a washer on the end where it broke.Still holding
fine.Replaced the broken right horizontal with the new design.
When I found both the verticals broke at the same time I repaired
both of them with some aluminum angle & some pcs. of rubber &
a couple of screws & locknuts.Cost a couple of bucks.Short
answer is you're not alone with this problem.
Old 05-22-2011 | 11:20 AM
coolerman69's Avatar
coolerman69
Iron head i've replaced both main supports twice! This last tine i did a little re-designing to the new brackets and added a rubber isolator. My concern is why does mine keep breaking and other guys i know with 40 50 k miles have never replaced one.?
Old 06-27-2011 | 03:38 PM
Bushy's Avatar
Bushy
ANYONE HAVE PART NUMBERS ON BOTH THE sPEAKER SUPPORT AND MAIN FARING SUPPORT??
Old 06-27-2011 | 03:54 PM
locodude's Avatar
locodude
how do you know if yours is broken? I hear about this a lot but have never checked mine and honestly don't even know where the are located if I did want to check them out.
Old 06-27-2011 | 04:35 PM
steelerdude1's Avatar
steelerdude1
Both of my left supports broke. I repaired them rather than replacing them with parts that will break again. No problems since.
Quick Reply: Those d@#% fairing brackets
