no extensions for PYO 10" monkey bars
i was looking through some threads on here and saw that some say you need extensions and some say you dont.
well i just got my 10" monkey bars on and you dont need extensions for anything. IF you have the bars pushed forward.
you need to re route clutch line, re route your harness in the faring, and straighten out the steel brake line.
if you plan to rotate them back, then youll need extended brake lines.
Mine are pulled back and mine lines are stock.
I opted to go witha +4 clutch cable. The stock one was too tight, and when I rerouted it i wasnt happy with the way it looked. A big hole in my fairing for no reason? Uh...no thank you. Barnetts +4 Clutch cable at Dealership was only about $38 I think. Everything else is fine and I have ABS.
So to be clear, you just bought the bars, and if you dedicate all the time to do it yourself that's the total cost? Just when I had convinced myself stock bars were gonna cut it........
How do you like the 10's, any pics, and do you wish you'd gone bigger?
Kokes58
02-04-2015 03:41 PM
