OEM 2007 Ultra Exhaust
Old 05-21-2011, 09:28 PM
Gymshorts8's Avatar
Gymshorts8
Gymshorts8 is offline
6th Gear
Yes you r right I had the part # s mixed
What would happen If I ran without any cat muffler on either side would there be any performance difference or engine damage
Old 05-22-2011, 07:12 AM
skratch's Avatar
skratch
skratch is offline
Received 4,370 Likes on 2,543 Posts
i don't think you had a cat anyway. but no, you would not damage your engine, and if you add a different exhaust, you would probably notice a slight increase. you would see a lot more if you went with the full stage 1.
fuelmoto was recommended a couple posts up. i echo that recommendation. good folks, and they won't steer you wrong.
Old 05-22-2011, 10:15 AM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
With stock exhaust most of the exhaust gases go thru the right and at 3K rpm it will suck air in on the left instead exhale"I heard".
Old 05-22-2011, 11:18 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
just pull a set of an 07 ultra
65538-07
65846-07
Old 05-22-2011, 11:38 AM
coolerman69's Avatar
coolerman69
coolerman69 is offline
get some slip-ons of your choice and a Fulsac true dual kit. Front head pipe stays the same and most of rear cyl stays. I had one and it worked great, easy to install.
Old 05-22-2011, 11:57 AM
sparky_mo's Avatar
sparky_mo
sparky_mo is offline
I've got an 07 RKC. Like 'skratch' and others have said, you never had a cat. 80% of exhaust comes out the right side because of 2-1-2 exhaust system on a Harley.
Old 05-22-2011, 05:48 PM
skratch's Avatar
skratch
skratch is offline
65538-07
65846-07
did you happen to notice that those are the stock numbers that he has?
drpcfix
Touring Parts
02-27-2019 12:01 PM
Port Dawg
10-11-2011 10:57 PM
tporcarello
09-08-2010 04:27 PM
scotty3times
Wheels/Tires
07-20-2010 12:36 PM
Whiskers
Exhaust System Topics
06-26-2005 03:53 AM
Quick Reply: OEM 2007 Ultra Exhaust
