Have a 2005 ultra classic only has 17,000 and I am going thru 1 qt of oil ever 1500 miles or so. No smoke out the pipes,small amt of oil in in air cleaner. Pulled the plug some build up on plugs.
Yep, as stated "valve-itis" Needs the valve seals updated to the newer style. There's a bulletin showing the difference between the green and the orange one.
Valve guide seals. Mine was on the rear cylinder only and that was the only one I replaced seals on several thousand miles ago. If you have deposit build up on both plugs, then you have the problem on both cylinders.
The other suggestions are probably a more accurate fix but I too was going through a quart to a quart and a half between oil changes when I was still running dino. Since I switched to Amsoil I have zero oil loss.
