Just ordered a Fuel Moto PC5
I have a pc v for over a year, and have only used the map from fuelmoto. Which was fine, it ran relatively well. Finally just two weeks ago I took it in to be tuned (DYNO). Oh my gosh, the fuel/air mixture was too lean. Now it is so much smoother, no matter where the throttle is. And the bike runs a lot cooler. I noticed that you are in Dallas and a good tuner is Sabin Performance Shady Trail in Dallas. Very resonable and will spend as much time with you and your questions that you want. You cant go wrong with the PCV and a good tune. But at least the PCV. HTH or pm if more questions on tuning.
Bottom line is Jamie's maps will definitely get you close, and he is more than willing to work with you if the first map doesn't work out, but there is nothing like having your bike dyno'd and dialed in. Something you might want to consider. I'm definitely going to go that route once I have the funds for the dyno.
Interesting you should say that. I got my PC-V from Fuelmoto and installed it about a month ago. Like you, I think the bike is running pretty well with the exception of some mild decel popping in the 1400-2100 RPM range. Nothing major or loud but you can hear it at least half the time, probably a sign she's a bit lean in that range.
