Clutch Adjustment Question
Just got my bike back from it's 1000 mile checkup and the clutch does not grab until the last half inch of release, which I hate. When backing off the clutch adjustment screw which is suppose to be 1/2 to 1 turn, is it the closer to 1 full turn which affects how close to the bar the clutch starts engaging?
I think I understand everything else about adjustment from searching, but I am just a little foggy on what backing off the adjustment screw affects. I'm guessing the tech backs off a half turn. There was also no freeplay in the clutch lever, I thought there should be just a little freeplay at the end of lever travel. I'm thinking that is controled by the adjustment in front of the motor. Maybe I should just run it back in the morning and have him redo it since it was just done Wed. Opinions and answers appreciated!
Backing the screw out further will make the clutch grab sooner (closer to handlebars). The way to adjust it is when the bike is dead cold. Collapse the cble adjustment completely, screw in the adjustment screw until you feel slight resistance. Back the screw out 1/2 to 1 full turn and lock it down. Expand cable and you're done.
I would take it back, and ask them to readjust it. But that's just me. Mine has always engaged in the first 1/3 of the full travel distance. As for the other part of your question, I don't know yet.
I am about to start doing my own maintenance real soon. I just received my "Fix my Hog" DVD, and the shop manual is on order. Good Luck.
![Icon Shrug](https://www.hdforums.com/forum/images/smilies/icon_shrug.gif)
Thanks James, that was what I was looking for. Rode my buddies bike and the same dealership set his up the same. I do have the service manual so that is not the problem. I like mine to feel just like Harpoonman explained how his clutch feels. The way mine is setup I feel that you never know if you have complete engagement. I thought about taking it back up, but then the bike is no longer cold so I figure be just as easy to do it myself. Thanks for the help guys!
Adjust only when bike is cold. Collapse the cable adjuster in front of engine.
Loosen the locknut at the clutch basket and back off a couple of turns.
Pull the clutch arm against the grip with your thumb and fore finger using very light pressure. Screw the adjuster at the clutch basket in until you feel it trying to pull the clutch arm away from the grip. Back off 1/2 to 1 turn. Lock the locknut and do the final adjustment at the cable adjuster.
He said it's hard for some to get the correct feel doing it by the Manual.
One of the best HD Tech's I've met gave me this tip for clutch adjustment.
Stay with the manual, what your doing when adjusting the bolt at the clutch hub is removing excess lash between the cable lever in the right hand trans cover and the end of the rod that moves the clutch plates in and out. The backing off 1/2- 1 turn is setting the clearance for expansion when at operating temps. The cable is what gives the 1/16-1/8".
