Mustang Adjustable Backrest vs HD Adjustable Backrest
Old 05-14-2011, 04:30 PM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
Default Mustang Adjustable Backrest vs HD Adjustable Backrest
Which one is better?
Is one more versatile then the other? The Mustang is a lot cheaper.
Anyone have pics of the Mustang mounted to either a stock seat, or better yet a Road Zeppelin?
NOTE: I have the Kuryakyn Heat deflectors that will cover the mounting location of the HD adjuster Tab, It would still be useable, but difficult to get to. Does anyone know if there is a way to mount the adjuster in a different location?
NOTE 2: looking to pull the trigger on one or the other. I can get the Mustang Smooth (new) for $203 shipped or I found a used HD Comfort stitch one for $220 shipped not a big difference in price. what would you guys buy?
Old 05-14-2011, 04:45 PM
hojones's Avatar
hojones
hojones is offline
I switched to the Mustang BR when I bought the Mustang seat. It is a lot easier to remove when you need to and a lot more adjustable. Plus it matches the seat.
Old 05-14-2011, 04:46 PM
mike5380's Avatar
mike5380
mike5380 is offline
I bought the HD backrest when I bought my 2010 RK last year. I loved the backrest, but couldn't stand the OEM seat. So, I bought a Mustang solo with matching backrest.
The HD backrest has a much more solid mount, but it does not have as much freedom to move as the Mustang. It would move only an inch or so forward and backward, but the mustang actually has about twice as much adjustment. Also, the Mustang lays down nicely right on top of the seat so you can swing your leg over much more comfortably, that's important when your short legged like me.
The Mustang mount is only a single flat bar which makes it a bit flimsy in my opinion.
Either one makes a long haul much more comfortable.
Hopes this helps.
Mike
Attached Thumbnails Mustang Adjustable Backrest vs HD Adjustable Backrest-roadking2.jpg
Old 05-14-2011, 06:02 PM
steelerdude1
Hopes this helps.
Mike
How does the Mustang adjust, It doesn't use a cable right?
Ronp42's Avatar
Ronp42
Ronp42 is offline
Account Retired
I've had both! I'll take the Mustang 2 to 1 over the HD. JMO
Old 05-14-2011, 08:17 PM
C908's Avatar
C908
C908 is offline
I looked at both and did a lot of research before ordering the Mustang for the stock seat on my 2010 Ultra Classic. It is very adjustable and pretty much a perfect match, I'm very pleased with it.
Old 05-14-2011, 08:26 PM
G20's Avatar
G20
G20 is offline
The Mustang goes up and down with a spring loaded detent type adjuster. The front to back adjustments are made with a large thumbscrew.
I am using a Mustang BR with my stock HD saddle and love it.
I hope this helps.
Old 05-14-2011, 09:27 PM
Wassup8687's Avatar
Wassup8687
Wassup8687 is offline
I've used both and prefer the HD. Both provide comfort but on the HD it's easier to adjust while on a ride. I also prefer the way the HD backrest mounts as it's more secure and would take a thief longer to get it off the bike.
Old 05-15-2011, 04:03 AM
Trailfndr's Avatar
Trailfndr
Trailfndr is offline
I use the HD adjustable backrest, and faced the same problem with mounting as I am running the HD heat deflectors. Solved the problem by carefully cutting a hole in the left side deflector to install the adjustment lever right onto the shield. Looks great, and easy to reach.
Attached Thumbnails Mustang Adjustable Backrest vs HD Adjustable Backrest-dsc00791.jpg
Old 05-15-2011, 06:43 AM
Weatheredge's Avatar
Weatheredge
Weatheredge is offline
...had the HD backrest Ok changed seats Mustang seat w/Backrest - e-bay'in the
HD backrest-question answered-IMO
Quick Reply: Mustang Adjustable Backrest vs HD Adjustable Backrest
