real world info on FM 107 kit
#71
#72
The biggest chore in dropping in a set of pistons and jugs is setting the ring gaps. Once that's done, you can just install the pistons into the jugs from the bottom, and then slide the assembly onto the connecting rod as a unit.
You leave just enough of the piston hanging down underneath the spigot to access the wrist pin. Then all you need to do is install the second wrist pin clip and seat the cylinder down onto the case.
The manual has us install the piston onto the connecting rod with a ring compressor attached. You have to work the piston up into the cylinder and then remove the ring compressor. Either way works, I think the first method is simpler.
#73
Anyone have suggestions for the 107 with the TW-777? I'm running cobra true dual headers and Vance & Hines mufflers with a Kuryakyn Hypercharger...wondering what program would be best to load my Mastertune with? I got ideas, but wondering what others did...also, did not do the CR upgrade...shouldn't need it, but if I do I'll be having Fuel Moto port, polish and put the CR in.
OldBoldPilot
02-07-2011 03:44 PM
