Power Commander and Coughs and Sputters
05-13-2011 | 04:59 PM
Do the throttle zero procedure first then go from there
05-13-2011 | 05:58 PM
Quote:
Originally Posted by
upstate tim
Thanks Tim, that makes more sense. I'm using the PCV5. It's probably a differnt type of connector. I have always used dialectric grease on all of my electrical connectors in the past.
05-14-2011 | 08:08 AM
It is the idle air control valve, clean or replace. Cleaning fixed mine
05-14-2011 | 09:20 AM
How difficult is it to take the air control valve off?
05-14-2011 | 02:23 PM
mine was air idol control as well,i replaced it but u can try cleaning it,remove the air cleaner its on the top of the throttle body small hole in throttle body with a round plastic thing mounted ontop,hose it down with some carb cleaner.
05-08-2014 | 10:11 PM
Glad I found this.
11-24-2020 | 01:05 PM
You might want to check-out your IAC....Hope this helps....
11-24-2020 | 02:32 PM
mike canuk
I could be wrong, but I bet he figured it out 9 years ago.
The following 2 users liked this post by Keithhu:
11-24-2020 | 07:29 PM
matchstick30
08-17-2014 11:47 AM
Mpc1177
07-01-2012 08:59 PM
MrHog
08-25-2009 07:18 PM
FX4
04-04-2009 07:24 PM
anubisss
03-08-2007 10:48 PM
2000 ,
acceration ,
air ,
cleaner ,
commander ,
cough ,
eagle ,
hard ,
harley ,
king ,
power ,
powercomander ,
road ,
screaming ,
set ,
sputters ,
stutters ,
throttle
