clunk of junk
Old 05-12-2011 | 10:20 PM
harleyiron80's Avatar
harleyiron80
Default clunk of junk
2008 flhtp 103 when your in gear 1st 2nd or 3rd doesn't seems to matter it will clunk when you give it gas or let off the gas what do you think the prmblem could be? thanks in advance
Old 05-12-2011 | 11:01 PM
lipster's Avatar
lipster
Slack chain in the primary
Old 05-14-2011 | 12:34 PM
harleyiron80
could this be my problem i checked my clutch today and the shaft where you put the allen wrench at had a wiggle ,so i adj. clutch per the manual and still have a wiggle in the shaft is it normal or do i have a issue thanks for your help
Old 05-14-2011 | 01:17 PM
lipster's Avatar
lipster
Wiggled after you tightened the lock nut?
Old 05-14-2011 | 01:24 PM
harleyiron80
yes it still wiggled after i tightend the lock nut doesn't seem right
Old 05-14-2011 | 02:33 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Replace the adjuster and lock nut.
Old 05-14-2011 | 02:45 PM
Guy2008Ultra's Avatar
Guy2008Ultra
Again the dirty word "compensator" come to mind do you get the BANG at start up? I get the same clunk when in gear.
Old 05-14-2011 | 02:58 PM
cooper57M's Avatar
cooper57M
also slack with the IDS too
Old 05-14-2011 | 03:33 PM
18BKLR's Avatar
18BKLR
Change out the shift linkage. Its worthless. Probably will tighten things up a little bit and you will get firmer and better shifts.
Old 05-14-2011 | 03:53 PM
harleyiron80
i already replaced shift linkage the 2008 police came with se compensator. it runs fine and starts without any noise, just a clunk when you give it on and off throttle like theres slack in the primary
Quick Reply: clunk of junk
