Cams - Low End Torque
I have a 2002, 95", Ultra Classic that is nearing the dreaded 40K mile mark. Gonna have to go gear driven cams. I do quite a bit of touring two up and loaded, so I want a gear drive set that really delivers the mail from 2,000 to 4,000 RPM. I would like some feedback from anyone that has installed a set that feels they are getting the performance they were looking for bottom end. Feedback with "experience" will be appreciated.
Thanks,
Thanks,
RE: Cams - Low End Torque
Chief
Take a look here and check around before making your choice as the wrong cam selection can be worse than you have now and not give you the grunt in the area where you are looking for it. Any time modifications are made, they must work with other modifications that have been or will be done to maximize the total package.Give the cams some thought as to what else you may do in the future for you to make an appropriate choice.
https://www.hdforums.com/m_71922/tm.htm
The LOWRIDER*64*
09-12-2013 08:09 AM
