Drive Belt Change
Old 05-12-2011, 08:41 AM
69cj's Avatar
69cj
69cj is offline
Default Drive Belt Change
What's the easiest way to pull the clutch to change the drive belt. I have the primary cover and chain off. Just thought I'd check with the pros. Thanks in advance. Mike
Old 05-12-2011, 08:53 AM
Beeracuda's Avatar
Beeracuda
Beeracuda is offline
I don't know of an easy way. You basically pull the outer primary, clutch & compensator, starter, inner primary, rear wheel and swing arm. I can't see any quicker way around that.
Old 05-12-2011, 08:56 AM
Beeracuda's Avatar
Beeracuda
How many miles are on the belt? I am about to change mine at 105,000 because I already have everything apart because of a broken main shaft.
My belt still looks decent and I wouldn't be afraid to run it for many more miles. Unless the belt has some issues, I don't see changing it.
Old 05-12-2011, 09:16 AM
69cj's Avatar
69cj
69cj is offline
Belt has 41,000 miles but has the pac-man syndrome.
Old 05-12-2011, 09:24 AM
traveler's Avatar
traveler
traveler is offline
Pac-man syndrome?
Old 05-12-2011, 09:39 AM
Beeracuda's Avatar
Beeracuda
Then it is definitely time to change it.
Originally Posted by traveler
Pac-man syndrome?
That's when the ribs separate from the belt and look like little Pac-Men.
Old 05-12-2011, 10:05 AM
strtarrow's Avatar
strtarrow
strtarrow is offline
If it ain't broke don't fix it. IOW unless it shows wear on the sides or you picked up some sort of debris why would you change it?
Old 05-12-2011, 10:18 AM
sargek's Avatar
sargek
sargek is offline
Dumb question but why pull the swingarm when you could pull one or both shocks? Unless I am missing something obvious, with the shock(s) removed, what would be preventing the belt from being pulled back over the swingarm?
Old 05-12-2011, 10:34 AM
sfchief's Avatar
sfchief
sfchief is offline
Pulling the shocks is no help. You would still need to get the belt inside the frame tube that runs under the primary. Only way to do that is remove the swing arm.
Old 05-12-2011, 10:36 AM
sargek's Avatar
sargek
sargek is offline
Ah, OK, don't have a picture and was going off memory about other rides. Guess that's why they make the belts so bulletproof!
Quick Reply: Drive Belt Change
