Drive Belt Change
Old 05-12-2011, 12:14 PM
traveler's Avatar
traveler
traveler is offline
I am NOT looking forward to doing this!
~Joe
Old 05-12-2011, 12:30 PM
slothy's Avatar
slothy
slothy is offline
YA aBOUT THE only think i miss about my roadstar, lower swing arm pivot and slide belt in. 20 min job...
Old 05-12-2011, 12:31 PM
69cj's Avatar
69cj
69cj is offline
I'm down to just the swing arm now. If it helps anyone, don't disassemble the clutch pack unless you want to inspect the clutches. Mine are all still in spec and I'm adding a S.E. diaphram spring and S.E. compensator while in there.
Old 05-13-2011, 05:54 PM
69cj's Avatar
69cj
69cj is offline
Well, finally done. New drive belt, SE compensator, SE clutch diaphram spring, tires, brake pads, rotors and wheel bearings. Took about two short days, 10 hours total labor, and a day, 5 hours, chasing parts. Clutch pads well with in specs however found one steel plate where it shouldn't have been. Corrected that. Went with a slightly larger rear tire, mu85B16. Did a drive way run and all seems well. Will try a highway test tomorrow. It's beer time. Never worked on a Harley before. Always had Limey bikes. All seems well. The work shop manual definitely stopped me from making some mistakes and spotted the clutch plate out of position. Used a Harbor Freight lift and C clamped the frame to the lift. Saved some major problems when removing and installing tires. Major weight shifts.
Old 05-13-2011, 07:40 PM
traveler's Avatar
traveler
traveler is offline
Nice R code Mustang, BTW.
Old 05-14-2011, 08:29 AM
69cj's Avatar
69cj
69cj is offline
Thank you. I'm the original owner. Got it while in Nam.
Old 05-15-2011, 10:35 PM
traveler's Avatar
traveler
traveler is offline
Thanks for your service.
....and Welcome Home.
I too have a Mustang I bought new.....Garage queen 2001 GT. Put alot of money into it. Love the Mustangs.
~Joe
Rochdale1970
General Topics/Tech Tips
13
12-03-2020 10:56 AM
Neil
10-10-2019 08:45 PM
vanzant68
04-23-2014 03:13 AM
tekeum
07-03-2012 02:41 PM
kisskrazy
04-18-2005 11:57 PM
Quick Reply: Drive Belt Change
