Sick To My Stomach (cruise control)
Old 05-12-2011 | 11:23 PM
iwillfixthem4u's Avatar
iwillfixthem4u
That green connector is a PITA. The CVO models don't have the green connector and I'm fairly certain are internally wired, so the MOCO probably acknowledges it don't work internally wiring with that connector very well.[/quote]
The CVO TBW is for sure the way to go. comes with long wires that do not have the Green connector. Just under $100 and well worth it.
Old 05-12-2011 | 11:36 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Originally Posted by Bill03E
have someone look at the rear brake lights , hit the front brake , if the lights don't get brighter, it is your front brake switch.
Rear brake light? Is there any other brake light ?
Old 05-13-2011 | 06:48 AM
rg_dave's Avatar
rg_dave
If you have trhrottle its not the green plug. Check that all the pins in your molex connectors are locked in position. I had that happen on mine. I had one pin not locked in and my cruise wouldn't work.
Old 05-13-2011 | 09:06 AM
vzts4q's Avatar
vzts4q
Default Trouble shooting
From the electrical service manual.
I recommend that anyone who ever works on their own bike to buy one of these!!!!
Kill switch in run position
Hold cruise to set position
Turn on ignition
Cruise light on speedometer should be green
Release set on cruise light should be red
If it stays green you have a switch problem or pinched wire
if it is red make the other switches one at a time
all the following should turn the light green
set
resume
front brake
rear brake
clutch
throttle roll forward
Old 05-13-2011 | 10:27 AM
roadgliderick's Avatar
roadgliderick
just had mine replaced it was bad. but it is true u may have a pinched wire somewhere in that switch housing.
Old 05-13-2011 | 11:49 AM
hullhorr's Avatar
hullhorr
Originally Posted by smithbrl
I'd think that if the green connector came loose that you wouldn't have any throttle control. Permanent limp mode.
You would think, but not necessarily.
Originally Posted by SG_Dave
If you have throttle its not the green plug.
Not true. The same happened to me and many others I have conversed with on this forum and another after trying to internally wire with that damn connector in there. The green clip only latches on one side, which allows for some separation of the clip if it gets bound up trying to pull it thru the bars. Just as your molex plug wasn't connecting to one wire that clip opening just a little does the same thing.
Old 05-14-2011 | 12:07 PM
TerryLe's Avatar
TerryLe
4th Gear
It's not the brake switch. I wedged it open when I removed the cluster from the bars. Also, I checked the light when I reassembled everything. I'm pretty sure the green connector mentioned by "hullhorr" is the problem (now that he mentioned it) but I'm going to give "vzts4q" suggestion first...it's easier than dissasembling the controls. Thanks.
Old 05-14-2011 | 12:41 PM
TerryLe's Avatar
TerryLe
4th Gear
OK. I just tried the sequence "vzts4q" suggested and everything is in accordance with the directions. So,....I guess it's the connector in the handlebars. I'll give that a try in the next few days since the weather is getting pretty bad.
Old 05-14-2011 | 05:39 PM
gwvulcan's Avatar
gwvulcan
You could have just busted the little cruise button when you put the handle bar housing back together. When I swapped my bars, that is what happened to me. I overtightened the assemble and broke the little relay button, which took forever and a day to figure out. Lucky, I figured that out before I undid the handle bars and started pulling wires.
TLM
09-20-2024 08:21 AM
harleybob815
16
12-31-2022 12:35 PM
jblass
07-17-2018 10:28 AM
FatTony
07-11-2012 07:45 AM
ElectraLarry
08-21-2011 01:23 PM
Quick Reply: Sick To My Stomach (cruise control)
