What a difference Upgraded Stereo made to my bike
Have a 07 Electra Glide Classic . today i installed a Whole new system in bike.. removed Harmon KLardon stock stereo , speakers and installed a Hawgwired adaptor to fit aftermarket radio and used thier wire adaptor kit to upgrade to a Sony Radio. regaurdless i went with Pioneer so i had to Butcher the plug n play harness to fit the new stereo. then added a JL dx400/4 amp measures 8x7x1 1/2 fit on top of radio pretty much. then changed speakers to JL 6.5 mid range woofers and some 1 1/2 tweaters(had to cut holes for tweaters to mount in fairing) . then ran wires under tank and seat to battery and ran speaker wires out the back and installing some 6x9's in the saddle bags.. yes im cutting the front slash cut side of the bags to install the 6x9's (which im scared to do but doing it anyway since its what i want).. after HOURS of wiring and installing i finally got to test it with just front speakers then the rears not installed just plugged in and it was Amazing .. then started bike up turned stereo up and was amazed when i rev'd it up the stereo was Clear and LOUD.. would i do it again Yes but prolly pay to have it installed next time lol.. total cost so far is about 1200 since i went Hi End stereo parts .. Pioneer is also HiDef and has USB poort on front so i can plug a memory stick in and have a Jukebox worth of tunes.. also sold stock radio on Ebay for 525 so it covered alot of the added costs i went above and beyond the need of.. also the stereo will work with the stock finger controls but the Radio has to be programmed to do it, only volume control works as plug n play ... love the look of the radio.. and for long rides wont have to carry cd's or an ipod with wires danging anywhere , and i will HEAR what im listening to riding behind other Loud Bikes ..
i did have to trim a few things to get the amp to tuck above the stereo. the bezels that hold the speedo and tach in i removed and trimed the bottom part off gave me about an inch more i could push amp in... it Will be a tight fit when i finish today... i will get more pics when i get closer to having it done and all buttoned up.. and the tweaters required Cross overs so i have 2 cross overs, amp and lots of wiring . wont be a Pretty picture . if i had more room to work with i could of done alot cleaner install.. had to jam and tuck things where i could .. but yeah today when i finish i'll post pics of everything..
and no not marine stuff. the radio kit has an adaptor that has orings around it that seals it but the radio itself is normal Stereo... and for the speakers i covered them with a Speaker mat to help keep dirt and road grime out of them.. and i try not to ride in the rain so should be fine.
Good to read that you're happy with what you've installed.
Carl
I agree with Carl, 5" is a tight fit for the Vibe & Arc 4 channel amps. How did you manage to get 7" to fit?
posted a couple pics of inside the fairing. like i said i had to mount things like the cross overs next to speakers in a wierd possition and the amp fit pretty easy actually.. actual amp size is as follows direct off JL's website .. 8.52 in. x 7.09 in. x 2.05 in.
http://mobile.jlaudio.com/products_amps.php?amp_id=576 ... i would post more pictures but it only let me post 5 ..
only way AMP fit is cause i took the rings off the speedo and tach gauges that hold them in and grinded the pieces at an angle so amp would slide in another inch or so .. fairing went back on pretty easy. but my damn windshield screw anchors pulled out on 2 and are spinning inside the fairing.. what crappy design they did on the top 3 screw mounts for windshield ..
