best lowering kit for Street Glide?
Old 05-10-2011 | 09:59 PM
Louie Champan's Avatar
Louie Champan
I recently purchased a lowering kit for my 2011 SG from Road6Customs. It took me all of about 20 minutes start to finish to install them, no troubles whatsoever and no interference with the bags at all. Very satisfied after riding 400 miles, didn't change the ride at all, IMHO.
Louie
Old 09-29-2014 | 06:30 AM
bogieb's Avatar
bogieb
Louie
Resurrecting an old thread because I just got a 2011 SG and ordered Road6Customs lowering kit. My question is for Louie - did you drop yours SG 1" or 2"? I'm thinking 2" would do for me since I previously had an '06 (with 12" shocks instead of 13" shocks) which I lowered an inch and that was just perfect. Just looking for some feedback on if 2" is feasible on the SG (I'm 120 pounds and never carry passengers, so the shocks are not stressed at all, if that is a consideration)
Old 09-29-2014 | 08:40 AM
fat daddy's Avatar
fat daddy
I don't know why anybody that only spends $20 k on a bike would want to spend that much $50 dollars on changing the suspension! I mean hell man ya ought to be able to find something at the dollar store!!!!!!
INJEKTER (01-08-2019)
Old 09-29-2014 | 04:47 PM
bogieb's Avatar
bogieb
Thanks for being helpful Fat Daddy.
Old 01-07-2019 | 09:38 PM
Kdonny89's Avatar
Kdonny89
5th Gear
Default 2006 Street glide.
So I bought a lowering kit off amazon. its similar to the one everyone poste. it didn't come with bolts. what bolts did you use? and with my glide is it okay to do 2 inches or is 1 inch feasible. I just want to be able to firmly plant my feet on the ground.
Old 01-07-2019 | 10:29 PM
bklynbob's Avatar
bklynbob
None. It already lowered . Anything more could be unsafe.
Old 01-07-2019 | 11:00 PM
Kdonny89's Avatar
Kdonny89
5th Gear
Default Lowering
Well that doesnt help that I cant fully put my foot on the ground. Do I need to invest in shocks?
Old 01-07-2019 | 11:52 PM
Louie Champan
I lowered mine just the one inch. With just that amount of lowering and adjusting the air in the shocks you can still get a decent ride.
Old 01-08-2019 | 12:31 AM
Kdonny89's Avatar
Kdonny89
5th Gear
Default Lowering
Yea I was going to only do 1 inch. Should I add air to the shocks? What should it be at. I'm new to harleys.
Old 01-08-2019 | 07:45 AM
Sethc1020's Avatar
Sethc1020
I wanted to lower my 2012 RG about an inch as well but after doing a lot of research I found that the best options are a different seat or different shocks. I ended up getting a seat off of a 2016 street glide custom, you can find them anywhere from $100-150 used. If you go that route just make sure the seat says "Low" on the bottom. If you like your existing seat you can also send it to Mean City Cycles for a modification that will lower you down to your desired height.
Quick Reply: best lowering kit for Street Glide?
