NEW 2011 FLTRX problems
I would be furious by now. I'm sorry this has happened to you. Did you get a free HOG membership with your purchase? I thought those came with all new bikes. They will tow you free of charge if you do and if you don't have membership, they should still pay for the tow and give a couple of free services or something for all your troubles. This is the kind of crap that gives HD dealerships a terrible name. Speaking of that, maybe you should post the name of this dealership.
I have a 2011 RGU and had a problem with it going into limp mode. Had to replace the throttle position sensor. Dealer told me to turn off the rear cylinder shut off system since I had race tuner and SE255 cams. Have since installed LeNale cooling fan for parade conditions cooling. Hope this helps with your symptoms.
Darrell, I believe I sent you an email on here, but if you need more info could you give me your home email, and can email you all that I have found out. There are several things that need to be checked and if you have questions call 319-362-9496, and ask for Brad in service, he may be able to help direct your dealer on getting this problem fixed.
