A better than new 2008 FLHX
After putting 72,000 miles on my 2008 FLHX I decided it was time to go through the bike and see what needed to be taken care of. It had developed some vibrations I didn’t like and I had made the mistake of letting a totally incompetent individual work the front end; he was supposed to install a custom front end but six weeks into a three day job I told him to put the stock front end back on the bike. I later found a couple of things that make me think he was setting me up for a major malfunction but that is another story.
Accordingly, last January I went out of service to have the following done:
Cylinders bored, heads port & polish
SE Forged Pistons
Woods 5 Camshaft
Lower Unit Service; Crank repaired, balanced & welded (Darkhorse)
SE Flywheel
Manual Compression Releases
SE Compensator
+ All the new parts that go along with a 103 inch build
(connecting rods, push rods, lifters, bearings, etc.)
Thunder Max Ignition
Baker DD7 (7 speed) Transmission Kit
AIM Variable Pressure Clutch
Supper Trapp Super Meg 2:1 Exhaust
Chrome Front End Kit
Progressive Drop in Fork Kit
Braded Brake & Clutch Cables
Oil Temp Gauge to replace Air Temp
All engine and transmission fasteners replaced W/ 12 point polished SS bolts
I picked up the bike during Bike week and 3,500 miles later I’m very pleased with the results. I met the builder during Biketober Fest when I had him install a Glide-Pro, he is in St. Cloud which was close enough to where I was staying and Jake (Glide-Pro) had recommended him. If anyone is looking for a very talented builder in the St. Cloud area PM me and I’ll give you his email address.
SE Forged Pistons
Woods 5 Camshaft
SE Flywheel
SE Compensator
The bearings in my stock transmission were shot and I was going to spend money to tear it apart and replace them with the same HD junk. I understand Baker is working on a rebuild kit for the 6 speed which would cure the problem for a lot less money but I’m glad it wasn’t available when I had my build done, the DD7 is a marvelous piece of engineering.
