My Bike Eats Headlights!
Old 05-07-2011 | 08:36 PM
hdmg's Avatar
hdmg
Default My Bike Eats Headlights!
I bought an 09 streetglide brand new. The lowbeam on the stock bulb lasted only a few months. I bought the harley high output bulb and had to replace it a few months later. A few months later it was gone again. This time I drop about $50 on a PIAA extra special, high output, super duty, rough service bulb and low and behold it has lasted only a few months as well!
WTF is going on here?
Anyone else having this issue?
Any thoughts?
My volt meter is showing around 14 volts, so I don't believe it is a voltage regulator issue. Besides, I have had no other electrical problems.
For what I have spent on bulbs I could have bought a new LED headlight setup.
Old 05-07-2011 | 08:51 PM
rkoivisto's Avatar
rkoivisto
Default Bulbs
Really, if your voltage is not very high, which your gauge indicates it's not. The only three things I can think of that would cause the bulbs to go bad are:
1. excessive vibration
2. You are touching the bulb and getting finger grease on them.
3. You got bad axed luck and all your bulbs ar defective.
IMHO
Old 05-07-2011 | 09:23 PM
JR-Boston's Avatar
JR-Boston
[quote=hdmg;8290239...My volt meter is showing around 14 volts, so I don't believe it is a voltage regulator issue. Besides, I have had no other electrical problems....[/quote]
14 volts engine off?
14 volts engine idle?
14 volts at 3,000 rpm?
JR
Old 05-08-2011 | 02:35 AM
piasspj's Avatar
piasspj
My first guess, vibration . Make sure everything is snug, bulb and housing.
Old 05-08-2011 | 07:01 AM
Captain Itch's Avatar
Captain Itch
Sponsor
I have an 06 and a 07 Road King I have checked everything on both bikes,bought every bulb known to man..They will each burn out at about 4,000 miles..Had one go out again yesterday..
__________________
www.Captain-Itch.com
Old 05-08-2011 | 07:16 AM
1st 96 ultra's Avatar
1st 96 ultra
had head light problems on mt co. service van after I installed silver star headlights and did some reading on the subject and apparently the bright bulbs burn hotter and there for do not last as long , my guess is like a lot of stuff made these days they are not as good as they used to be
Old 05-08-2011 | 07:17 AM
JayStronghawk's Avatar
JayStronghawk
Guess I am Lucky still have all my OEM lights on the 09 Ultra with 29K on the Clock but I do cleck all my Sockets, Spray with Contact Cleaner and Dielectric Grease them once a year ..
Old 05-08-2011 | 04:12 PM
hdmg's Avatar
hdmg
I have been very careful about not touching the bulb during installation. Everything is good and snug.
I don't think my bike vibrates any more than any others I've seen.
As for the voltmeter, it indicates about 14 volts once you get the motor above idle and stays there thrfoughout the rpm ranges. There is no indication of any problems there.
As far as the brighter bulbs burning hotter theory, it makes sense, however the stock bulb lasted no longer than the brighter ones.
Has anyone tried the new LED headlights and what do you think of their looks and performance?
Old 05-08-2011 | 05:52 PM
NoKenDo's Avatar
NoKenDo
I have done a lot of investigating into the LED and, I have one on order
at my local HD dealer.
Click on the link in the 1st post of this thread.
dyna-rider
05-04-2011 09:10 AM
harris48cars
07-01-2010 06:32 AM
tjkelly375
EVO
09-11-2009 11:03 AM
kaynine840
09-17-2008 12:56 AM
ccmd2b
12-05-2007 09:41 AM
Quick Reply: My Bike Eats Headlights!
