Today's project, gutted a 2011 2-1-2 pipe, with pics.
#81
#84
#85
#87
hello everyone.milf great write up.ok here is what i got going on i have a 2011 roadglide ultra i just bought a fuel pack.should i leave the head pipe w/cat and see what happens or not?.also i was thinking of gutting out my stock mufflers will i lose any back prusser?or what ideas does everyone here have what should i do.fund are alittle tight but i like to get a little more sound with what i have.
#88
i also did the same thing for mine. i found a 2-1-2 on craigslist for 100 beans for my '10 SG. i guess you can say i had a little OCD and didn't like the single pipe. i took a "sawsall" to it as soon as i got home. after removing the CAT, i took it down the street to a local welder and he tig welded it back together. sounds a lot better now since i got rid of the "weed wacker" sound. a buddy in Tx wanted my old one complete exhaust so i did the same to the old header before sending it to him. really easy to do and you cant even tell i did it.
Cep
Cep
#89
Tools used:
Vice, cut off wheel, air chisel, die grinder and welder.
Took about an hour to do. This is the second pipe i've gutted but the first time doing it this way. The last one I cut in two halves and drilled the cat out. Due to cutting it in half I lost about 1/8 inch in length from the sawzall so had some trouble mounting the cross over pipe on its bracket due to it being a little shorter.
So on this one the area I cut an access panel so I didn't loose any length. I tacked the four corners and welded the panel back in place. Once mounted the cuts and welds will be totally covered by the heat shields and will look totally stock appearing.
#90
I just did this yesterday to my 2011 RK ...prior I had added 3.5" Rinehart slipons...a SE airbox and had the download done at the dealer. Eventhough the air cleaner and ECM flash opened up the pipes and the engine was breathing noticably better ...this mod gave VERY noticable gains in performance. The bike is quite a bit louder and has a bit more decell " Rumble " ( not backfire ) ... when you hit the throttle you immediately get response as opposed to that delay you get as the backpressure builds at the cat .. the bike still runs great and I am glad I did it ... Thanks again for the Idea ( and cash savings ) ... Mark
