I'm going nuts SO HELP ME
Here goes wifes bike 05 softtail. Had cam work and new cam plate . Ever since then bike a miss in it. Could go temn miles or 30 miles it will skip and sputter. Dealer has had the bike 4 times same thing all set Wrong. Can anybody give me some ideas here . They have ckeck crank sen. fuel in, fuel pump, petcock, replaced a good PCiii. Now they are looking at the ecm . so help this driving me nuts thanks slick
Sounds like a bad or loose electrical connection to me. Vibration could be causing a ground or open circuit to come and go. Are you getting any codes? Try wiggling your wires and connectors with bike running and see if that doesn't simulate your problem. If you're getting codes they may point you to the cause. I check for any codes that may be stored. Good Luck!
